1 - 3 of 3 Posts
1995 Bronco XLT
So, after a ton of searching old posts, a lot of links don't work, I can't find anything in terms of necks. I've found the hose on Bronco Boneyard.
My question is, will an F150 or any F-Series work?
Also, my Bronco has to pass emissions to get registered and my fuel neck definitely has the venting issue where I have to fill it SUUUUPER slowly but does anyone know if there's a chance it could pass the fuel cap test with a neck that's not venting properly?
edit
Nvm, apparently I'm blind because I didn't see boneyard has the necks too. Feel free to delete and flog me for my idiocy 馃槤
1995 Bronco XLT
Discussion Starter #2
Okay so actually Bronco Boneyard is out of stock on this item currently, so now my question is applicable? I need this for emissions, does anyone have any advice?
Yo,
Stop by local Ford dealer parts dept because they may be able to cross reference the part number to F series;
They will look it up in the Interchange Guide data base.
The Ford bean counters deleted the public Interchange Guide and Buyer's Guide a few years ago to save their $ & make it more difficult for us to maintain our Broncos.
As an example, here is Ford Motorcraft's buyers guide info for a ""Motorcraft basic pn":
"12A646 is a relay.EEC power, mostly found under the hood next to the fuel pump relay on EFI vehicles. .
RELAY, ELECTRONIC ENGINE CONTROL (ASSEMB
DY-865 [Universal Relay] 2 Bbl.; E1VB-12A646AA,E3AF-12A646B1A,E3UF-12A6461A1,A2A, B1A,,B2A,E3TF-12A646A1A,A2A,B1A,B2A
and from the Buyers Guide:
Part No.: DY-865
Manufacturer: MOTORCRAFT
Part Type: ELEC ENG CONT ASSY RELAY
Total No. of Vehicles: 275
FORD (202) 1983-1994
AEROSTAR (9) 1986-1992
1992 V6-183ci 3.0L F/I Vin U
1991 V6-183ci 3.0L F/I Vin U
1990 V6-183ci 3.0L F/I Vin U
1989 V6-183ci 3.0L F/I Vin U
1988 V6-183ci 3.0L F/I Vin U
1987 L4-140ci 2.3L F/I Vin A
1987 V6-183ci 3.0L F/I Vin U
1986 L4-140ci 2.3L F/I Vin A
1986 V6-183ci 3.0L F/I Vin U
BRONCO (18) 1983-1991
1991 V8-302ci 5.0L F/I Vin N
1991 V8-351ci 5.8L F/I Vin H
1990 V8-302ci 5.0L F/I Vin N
1990 V8-351ci 5.8L F/I Vin H
1989 V8-302ci 5.0L F/I Vin N
1989 V8-351ci 5.8L F/I Vin H
1988 V8-302ci 5.0L F/I Vin N
1988 V8-351ci 5.8L F/I Vin H
1987 V8-302ci 5.0L F/I Vin N
1987 V8-351ci 5.8L 4 BBL Vin H
1986 V8-302ci 5.0L F/I Vin N
1986 V8-351ci 5.8L 4 BBL Vin H
1985 V8-302ci 5.0L F/I Vin N
1984 V8-302ci 5.0L 2 BBL Vin F
1984 V8-351ci 5.8L 2 BBL Vin G
1984 V8-351ci 5.8L 4 BBL Vin H
1983 V8-302ci 5.0L 2 BBL Vin F
1983 V8-351ci 5.8L 2 BBL Vin G... ETC,"
159731
鈥⒙扳
Check part number shown
鈻犫枴鈻犫枴鈻
In a YARD SEARCH on-line, I use;
https://www.hollanderparts.com
A yard that uses Hollander Interchange can search other yards and have it shipped.
"...For over eighty years, Hollander has been making the best tool for fast, interchangeable part matches. The new Edition Hollander Interchange contains more interchangeable options than ever before.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..."
See their yard Directory @: Seller Directory | Used Auto Parts | Hollanderparts
Your Search: 1995 >Ford > Bronco > Air And Fuel > Fuel Filler Neck > Alternate Fuel Filler Neck
  • They show four Broncos, but no neck pics. Other sources don't describe vehicle type
  • GL!
1 - 3 of 3 Posts
