Yo Andy,
Sorry for the delay!
Hardware Limited Operation Strategy (HLOS) Overview; "...HLOS mode is used when the system fault(s) is too extreme for the FMEM mode to handle. In HLOS mode, all software operations have stopped and the computer is running on hardware control only. The default strategy for this mode has a minimal calibration just to allow the vehicle to operate until it can be serviced. NOTE: IN HLOS MODE YOU WILL NOT GET ERROR CODES. The MIL light is turned on as a bulb check when the ignition key is first turned "ON". The EEC IV computer turns off the bulb as soon as it receives the PIP (crank) signal. If the light stays on during cranking, the computer is not receiving the PIP signal...
... However, Continuous codes that were set before the processor entered HLOS will be retained."
Could be an EEC ISSUE, pull it and inspect or if it has atge wonderful londdead fish aroma, replace,
