1 - 4 of 4 Posts
Personal Log of updates and maintenance
Bought May 19, 2016 with 83,302 miles, tires basically brand new.
Fixed Fuel Sender - May 22, 2016
Installed K&N Air Filter - June 12, 2016
Oil Change @ 85472 miles - June 19, 2016
Changed Rear Bumper Cover - June 21, 2016
Replaced Tailgate Window Switch - July 29, 2016
Installed Western Turbine rims - Aug 23, 2016
Timing Bump (was at 7 BTC, now at 12 BTC) - Sept 3, 2016
Coolant Temp Gage replaced - Sept 5, 2016
Rear brakes - Oct 23, 2016
Oil change 91451 - Nov 11, 2016
Fixed tailgate open latch - Feb, 23 2017
Oil Change @ 97260 - Apr 02, 2017
MAP sensor - w/used one June 30, 2017
Radius arm bushings back half both sides - Aug 16, 2017
Coil - Oct 1, 2017
Number 6 & 8 fuel injector plugs - Oct 2 , 2017
Oil change @ 105540 - Oct 22, 2017
Front brake pads- Dec 3, 2017 108250 miles
Oil change @ 113765 - March 18, 2018
Rear shocks @ 116112 April 29, 2018
Oil change @ 119771 July 2, 2018. 5w30 Mobil 1 with a quart of Lucas
Rear slip shaft lubed - July 6, 2018
September 16, 2018 - Ball Joints, Rotors, Calipers, Shocks, Springs, Sway Bar Links, Spindle Studs, ABS Sensors, Brake Lines Fronts and ABS Pump to Rear below Driver's Door, New Tires, Wheel Alignment 122333.4 Miles
Oil Change @ 126558 - Feb 25, 2019 5w30 Mobil 1 with a quart of Lucas
Oil Change @ 131642 - July 30, 2019 5w30 Mobil 1 with a quart of Lucas
Test Edit
Discussion Starter · #2 ·
Until I'm able to edit my original post I have to reply to it.
Oil Change @ 137153 - Feb 23, 2020 5w30 Mobil 1 with a quart of Lucas
Still not able to edit my original post...
Axle U-joint Drivers side @ 138663 on Apr 19, 2020
Yo,
I can do the edits if you wish.
I figure you know of;
"Click on the 3 vertical dots to the far right of the timestamp. Select “Edit”.
Members have unlimited editing of new posts for the first 24 hours after posting. Up to 10 existing posts (older than 24 hours) may be edited per week. More editing will be allowed as each of those 10 edits expires every 7 days."
1 - 4 of 4 Posts
