1 - 2 of 2 Posts
I have a 96 and the right is hard to rotate when the hub is locked in. The truck has 130K on it. The axles look like someone replace the universals on both axles. I am going to pull the hub off to regrease and check the bearings. I am also going to pull the spindle off to check the axle bearing. If this bearing is bad would that cause my problem or is it in the pumpkin or is the right side harder to turn? Nothing seems to be loose. Has anyone had this problem?
1 - 2 of 2 Posts
