1 - 4 of 4 Posts
It's usually like June, or there abouts for early release in September... U can tell what month and year a rig was manufactured by looking at the certification label in the door jamb.
Trivia: the 10th position of the VIN indicates what model year the vehicle is. S=1995, T=1996, etc.
To STSCOWBOY,
Welcome!
Call Ford Customer Relations.
Ford and Mercury United States(800) 392-3673
Monday-Friday8:00AM-11:00PM EST
Saturday 8:00AM-8:00PM EST
SundayClosed
FYI, in mid- to late 1996, Ford announced the discontinuation of the Bronco. The last model built rolled off the Wayne, Michigan assembly line on June 12, 1996.
BTW, I know Ford made a mistake by transferring production data to Marti, because Marti can't handle the data dump and probably isn't about to try for Bronco & other "non-collector car" models.
Build Date Stamp Location in 96 Bronco and F Series; "...The vehicle build date stamp is a four-digit number representing month and day of manufacture. On Bronco and F-150, F-250, F-350, the vehicle build date is stamped on the front surface of the radiator support on the passenger's side of the vehicle. For example, for a build date of January 24, the vehicle build date stamp reads 0124; for a build date of October 21, the vehicle date stamp reads 1021. Yellow ink is normally used for the date stamp. When the marking surface is painted the body color, the date stamp will be marked in red ink. Units from the Ontario Truck Plant (Code C) will be marked with silver ink..." by Ford
Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ Welcome to Ford Owner | Official Ford Owner Site; or @ Recalls Look-up by VIN (Vehicle Identification Number) ... have VIN ready.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
Please fill out your Bronco Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual), location info & major mods such as a Lift, etc. for better responses.
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @ FAQ
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ Baba Looey's Favorite FSB Links (lots and lots of tech links)
96 Bronco-F-Series Workshop Manual (PARTIAL) via 1996 Bronco/F-Series Workshop Manual
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ 1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Free registration for some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site .
See our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests
Al
1 - 4 of 4 Posts
