I need to remove the rotors off my truck but don't know how. Can somebody please give me instructions. Pictures would be great. Are there any special tools required. I am having difficulty with the hub removal. Thanks.
ok, if its the same as my 95 ull need a good pick, to get the retaining ring for the hubs out. then you will need a special socket for the wheel bearing nut(differs between auto and manual hubs) available at any auto store. i would suggest doing the wheel bearings as well. the studs will have to be pressed out to replace the rotor, and dont forget the wheel seal
I believe there is a write-up or two in the tech write-up section...
An option, though it's significantly more expensive, is to buy the new rotor with ABS ring and studs already installed...It's much quicker and simpler if you prefer that sort of thing;).
Yeah, like 95fsb said, go ahead and throw some new bearings at it while it's apart.
