Hey!
everyone new to the page, just got my own bronco a few months ago. But recently I just put gas in it. Then half way home the acceleration was sluggish then I tried to start it next day it dies seconds after it starts. After doing this several times it will stay running but a little rough. And then as soon as I push the gas pedal it wants to die but I release it the rpms jump up and stays running. Every so often I can actually get the the rpms up and rev and it sounds good but then I release the gas pedal it stalls. I have check fuel pump, psi, and changed fuel filter. and there isnt a check engine light either soo I'm lost.
Yo Rowellc1995,
Welcome and congrats on acquiring the best year Bronco! !
Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning
➡ If the CEL does not light up at all when starting it; then suspect that bulb is burnt-out or loose, socket was damaged by PO or shop, etc. or someone removed it.
Some no code usual suspects by Ford;
Vacuum leak, see my leak diagnosis link in post #11
One indicator of a leak is when A/Cis one, airflow reverts to defroster outlets.
Air filter, is it relatively clean?
Air inlet atop radiator support to filter box and to throttle body; look for obstruction; damaged tubing, openings in tubing, loose fit at throttle body or if equipped, at MAF sensor.
➡ Fuel quality; Oxidized fuel often turns darker over time and may even smell sour. You can check stored gasoline by pouring some into a clear glass container and comparing it side-by-side with known fresh gasoline. If your old sample looks noticeably darker than the fresh gas, you have strong evidence the gas has gone bad.
Electrical connectors; inspect for corrosion, etc at coil, firewall, ICM, distributor, PCM, etc. especially those with broken locking tabs.
Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ Welcome to Ford Owner | Official Ford Owner Site; or @ Recalls Look-up by VIN (Vehicle Identification Number) ... have VIN ready.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
On that first page, named Account Details,
scroll down to "Vehicle Info" and type in up to 100 characters.
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
Here's the 1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ 1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site .
See our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests
Al
also...this is the silver bronco i fixed up and sold. the build thread is here:
The Solid Silver Bronco
i told the OP that this forum was awesome for figuring out hard problems and he listened to me. i hope i was right.
