381 - 400 of 600 Posts
Ultra Premium Member
Discussion Starter #381 (Edited)
Addicted to Junk
What lift size are your coils?
Just snowballing here...
Six inch brackets, plus dropping the buckets 2 inches would really want 4" springs. Using a six inch spring would automatically cause the camber issue. A six inch spring in that case would make an 8 inch lift, but your pivot is still set at 6". If you wanted to net ten inches of lift, using 8" springs, you would need a 4" drop c&t beam. Just moving the lower BJ tab out doesnt seem like it would accomplish that 4" of drop.
At any rate, yea I'd start by pulling those spacers and installing the k80108 bushings. From my point of view that might get it back to where you started.
1986 Ford Bronco, 351w with edelbrock aluminum top end and holly 600.
“The 4” cut and turn should add no lift” huh? My understanding is that the 4” cut and turned beams eliminated the need for drop brackets because the 4” drop is build into the new shape of the beam. And they also fix the camber issue.
No?
Addicted to Junk
Discussion Starter #385
No?
Nope, beam shape is the same, moving the ball joint farther out corrected the camber using the stock mount w/4" of lift:
Desolate Motor Sports description:
"This beam package will correct camber on lifted vehicles and adds strength with smoother articulation.
We offer 4 different stages when it comes to a modified TTB on your Bronco or F150. The Stage 3 TTB remains stock width, is camber corrected, has plating added for strength, and beam pivots converted to uniballs. The difference between this and the Stage Two is the full truss that extends across the rest of the beam. We also open up the window on the passenger beam to prevent the axle shaft from contacting the beam at full droop. This is recommended for Broncos and F150s with increased wheel travel looking for better articulation and a stronger beam than stock.
Features:
Corrects camber on raised Broncos and F150s
Plating adds strength
Full Truss
Better articulation
Stock Width"
Discussion Starter #386
I think we are all getting a little confused here. The 4" cut-n-turn doesn't add any lift. The 4" cut-n-turn means the camber has been corrected for a 4" lift using the stock axle pivot location.
My 6" springs, 2+" of coil tower cut, 1/2" spring mount shim and my air bags gave me 9"-10" of lift with the stock lower ball joint mount. So, in theory, by using a housing with the camber corrected for 4" lift in the stock hole and moving it to the 6" hole, I should be good for 8"-10" of lift, correct? If the lowering bracket corrects the camber for a 4" or a 6" lift , depending on the hole used, shouldn't the additional 4" of lift be corrected with the camber modified housing?
Look at their picture, the mounting point is the stock location and the shape of the housing hasn't changed other than the lower ball joint:
Addicted to Junk
But then the beam is too short, and you'll be a couple inches narrow on the radius arm mount location in relation to a stock suspension. What you describe needs a 4" drop bracket to be correct, bot the stock pivot bracket.
The air bags have nothing to do with your lift height, if I understand right. They only stiffen the spring rate, meaning the spring doesnt compress as far.
Both drop bracket kits I have had had the 4 and 6" holes exactly above one another. And neither have totally corrected the camber.
My point is you have 8.5" of spring and dropped bucket trying to pivot where a 6" spring would normally be. (Then 2" of spacer!?) Since the C&T didnt move the spring perch lower, you are trying to compress too much spring. See how steep of an angle your beams are at? Either lower the pivot farther or remove spring height.
Put that set of ttb beams on my drop bracket kit in the 4" hole and I bet itd be perfect without the k80108 bushing.
You could maybe simulate a shorter spring by adding the plow weight on the front. That would compress the spring farther, therefore fixing your camber.
If I were going C&T, itd be this style, that is cut and turned inboard of the differential and lengthened to eliminate drop brackets altogether. 6" brackets plus 4" lift c&t beams in this manner would net 10". I just dont see how your style allows any more than 6" of spring on your 6" brackets. Then you dropped the coil bucket 2", so a 4" spring. A 6" spring may not compress enough to allow proper camber?
MidlifeCrisisUndrWay
1994 Ford Bronco XL 5.0L
My 6" springs
So, in theory
Even after shuffling around your post in a way where I might understand;
Me:
Discussion Starter #389
Blue, the airbags do add lift if you utilize the supplied spacer in the bottom of the spring so they have to grow taller. With the bags empty and the truck sitting on the ground, the truck would go up a little over an inch when inflated.
Here are cut-n -turn basics that migh explain things @CDA 455
@BigBlue 94 , Stand by buddy, I'll give you a call.
Discussion Starter #390
Okay, so yes the lift comes from the longer springs but the angle of the cut and turn axles eliminates the need for drop brackets.
So if you added 4” drop brackets and 4” longer springs I wouldn’t expect any change in camber since the entire system has been dropped.
If you just add springs or spacers then you start to change camber.
I’m still catching up on your thread so bear with me.
The C&Ts allow 4” of lift without needing camber correction.
If you add 6” of lift for a total of 10” I would think you would need to add 6” drop brackets to keep the no camber correction needed condition.
I would also imagine that you’d start having issues with you arms fitting or trying to rotate the axle forward.
I think I’m agreeing with what BigBlue is saying.
Discussion Starter #395
Correct, and this is accomplished using the factory mounting hole/pivot point
Already have 6" drop brackets and axles are in the 6" mounting hole
No sir, arms are longer, angled outwards at the axle end and have been dropped so they are close to factory level, therfore, they do not rotate the axle forward. Keep in mind, I never had a caster issue which tells me my radius arm geometry is correct.
I spoke with Blue yesterday and explained to him what was done as it was waaaaayyyy too much to type.I really think the 2" spacer is the straw that broke the camels back; that coupled with the 1/2° camber bushing. I will install a 3.2° bushings and let everyone know how it works out.
Think about it, I had better camber before. I increased my Negative camber with the new housings, so, in theory, I should have better negative camber now. I don't, I have Positive Camber, so what other things were changed? I added a 2" spring spacer and a pretty close to zero degree alignment bushing. (I don't know what bushing I had in there before, but I can tell you this much, it wasn't as close to center as the bushing I put in)So, if I remove the spacer and replicate the original bushing, my camber should improve.
Anways, that's my story and I'm sticking to it. :whiteflag
Discussion Starter #396
Gotta love Amazon Prime, my bushing was delivered on a Holiday.
Hope to get it installed after work tomorrow and spark off a whole new debate/discussion if it it doesn't work, hell, maybe even if it does, lol. :popc1:
Addicted to Junk
Fingers and toes crossed!
Discussion Starter #398
Yup, because of this thing doesn't work, I'll be fabricating some 8" drop brackets! :gears:
DUUUUUUU EEEEEEEEEEEEEEETTT!!1! :histerica :rofl: :histerica :rofl:
