I need some troubleshooting help, so here my story. (Truck info under name, still).
While leaving the camp grounds, I switched to my rear tank to idle. I normally keep about 3 gallons in it for idling only since the seal on the tank isn't 100%. The truck started to die, so I switched back to the front tank. Then I made the mistake of trying to figure out why it started to die and switched back to the rear tank. Truck started to die again, so I hit the switch again. Truck died anyway. I completely lost power to the fuel pumps, andhardwired battery power to the tank selector switch to make it home, overfueling horribly (black exhaust, bogging and rough idle). Found out that one or more of the fusible links connected to the starter relay had melted through. I replaced the links with standard blade fuses and the large 10 ga. wire ring terminal with a crimp on one.
Now I have power to the pumps as I should, but the truck still just barely keeps from overfueling at idle and rolls coal constantly and continues to bog under quick throttle. Even after resetting the battery (and therefor the EEC IV), I still get codes21, 22, 53, 54, and 35 in that order. the codes state that the ECT, MAP, PFE/EVP Curcuit, TPS, and ACT sensors are all above voltage. Are there resitors in the fusible links as well or something? Alternator charges right where it should, about 14.4V (140 amp 3G conversion) and I've never had problems with the alternator or regulator since I put it on.
Any ideas? I'm almost at a loss on this one.
