1 - 10 of 10 Posts
Too many broncos!
I need longer flange or non flange bolts that are used to bolt the stock A/C to the bracket so that i can mount up my York bracket. I seem to have to order them however before I do i wanted to get confirmation on the actual size..
are they M7 size with a 1mm thread pitch? I think I will need 140mm long.. and they seem to be a bit harder to find but wanted to make sure before i pulled the trigger. thanks!
House of Windsor 4ever!
I'd swear those are M8-1.25mm, as an M7 bolt would be a non-standard size in automotive use.
Too many broncos!
they probably are, I'm measuring off a ruler so not really ideal... thanks i will probably order some up here today, want to get the York back in the truck..
Former owner of Shadofax
I'm thinking this is right as well.
But Chris, do you have any of your hard top security lock bolts laying around? I used 3 of the shorter side ones to secure my dummy pully before I did the OBA....those are metric and a "fine" thread. Just take one and carefully thread it on there to confirm and then go down to Lowes. I bought some metric 8.8 (grade 5? equivalent) from them in the length I wanted right out of there bins when I put the OBA compressor on.
Here you go, these are the hardtop security bolts that thread right in on mine:
Too many broncos!
hmm well i have one of the bolts out of the bracket.. but i have never had good luck at home depot or lowes finding bolts.. i will take a ride and see.. i need 140mm so hoping someone local has em. i know ace doesn't have them. Already been by there.
1995 XLT SAS w D44 and D60 rear
If you are ever up to Boulder Mcguckins has almost very bolt I have ever wanted. And you get to buy what ou need not the HD way of 1 bolt 3 washers and 2 nuts:banghead. I also discovered the Lafayette Jax has a pretty good bolt selection by the pound.
Too many broncos!
just check their bins, but that is long, roughly 5.5" long bolts?
yup just about 5.5" I have to add 1" spacers in from the A/C bracket under the York bracket otherwise the York bracket is too low.. also the A/C bolt holes are lower than the A/c compressor so it binds whatever you have mounted to it..
thanks Matt.. I just might have to make a run up there as I have the hardest time finding stuff here in Denver for some reason, I just dont know the places to go yet.. but getting there!
iam headed out today to find my bolts!
Too many broncos!
ok got em.. the metric supply 1 mile from my house had 6 in stock so i bought all 6... i seem to use stuff again anyway and nice to have a few extra on hand!
hopefully get the york back in this weekend and get that cable together so I can say i have a TC/ebrake!
Still waiting on that brake to be tested.....:popc1:
But in the meantime, I couldn't wait any longer...just ordered the procomp 23411 leaves for the rear vs. my block/AAL I've had for a Loooooonnnng time. Couldn't beat the deal, guess through who???? 4WPH....$174.99 ea. and ships free.
1 - 10 of 10 Posts
