One of my upcoming projects is to tackle the A/C system on my '92 Bronco.
I bought the truck this past summer and the A/C although complete does not work. Not worried about why really the current system does not function as probably no A/C charge. Never even bothered to check it out. This system is still a freon 12 system and has never been upgraded to the 134a.
Considering that my plans are to keep this truck long term (10+ years) when I redo the system I will do a 134 system due to how scarce and expensive it is to source any r12 even today. I can still get r12 right now but you are looking at about 25.00 per 12oz can!
In the past I have "converted" 12 systems to 134 and they work great running down the road but in heavy stop and go traffic and only being able to use about an 80% charge on the 134 due to system pressures the performance of such converted systems seems to leave a lot to be desired as far as maintaing adequate cooling in those excessive sitting at stoplights in heavy traffic situations so I am looking for a better upgrade path.
So what I have been considering as a possible option is to install a complete new system but buying parts for say a 95 or so where the 134 was the factory installed refrigerant and then the cooling performance in theory should be good in all situations.
I am talking about new compressor, condensor, drier, hoses, evaporator, pressure switches, orifice basically the entire system. Just doing some parts specs comparing it does seem as if the newer factory 134 systems evaporator is slightly larger than the older R12 systems.
What I am wondering is if anyone knows whether the underhood evaporator box is different on the newer 94+ systems or whether the newer evaporator would possibly still fit in the '92's box?
I am just speculating but considereing the trucks changed very little in the last years I am hoping that it may be fairly easy to adapt the later model pieces to the slightly earlier truck.
Is my logic correct that by upgrading to the complete newer factory system that is designed for the 134a that I should be able to duplicate the newer vehicles ac performance including heavy traffic situations?
I have a '94 Dodge Dakota that came with the factory 134 system and that system performs extremely well in all situations.
Any way I go will probably be about the same cost wise as I will be replacing all the componants in the system as I want to do this once and have dependable, basically leak and trouble free ice cold AC for some time
Anybody that can shed some light your response is appreciated. Thanks
