1 - 8 of 8 Posts
Does any kind of gasket go under the aluminum pan under the intake or does it just sit on there? And what are the intake bolts supposed to be torqued down to?
Thanks
Cameron
FSB warrior
Thanks
Cameron
Is it the spider for your roller lifters??? or is it your lower intake manifold you are talking about??? If its the latter hell ya there is a gasket.
Check in your haynes manual about the torque.
green ones make me horny
yes there is a gasket that goes on it. There is a gasket that goes on damn near everything for the intake
I'm talking about underneath the very thin aluminum pan underneath the actual intake. One 351M I have had silicone underneath, and the one on the bronco had nothing underneath it.
Cameron
it called a valley pan and no...no gasket is used....that is the gasket. but i do use indian head shilak on mine ....or silicon as said earlyer would work
No avatar required
As stated above it is the gasket, Autozone had one in stock when we did the engine swap. It was $25.
Discussion Starter · #8 ·
So nothing goes underneath it, but do I use the gaskets that I ordered that go on top?
Sorry if I'm confusing anybody, I'm confusing myself more.:banghead
1 - 8 of 8 Posts
