1 - 20 of 106 Posts
After some street driving and turning, a few funny noises and a wheelin trip
yesterday, it went bang.
I havent removed the cover yet. But I will and Im going to do a full before
during and after thread with pics and a video of the rear driveshaft spinning
and the rear tires doing nothing lol...
Well, you said you wen't going to replace it till it was broke...Nows your chance.
I've heard good things about the loc rite, but I wouldn't pay 290 for one.
Well hook a bronco brother up. My two usual sources have them for 290 and
thats before shipping.
JBG has a Ford loc-rite and a powertracks loc-rite, same price
Designated Tranny Killer
You'll break a bunch of 8.8"s with 38"s. Put a 10.25 in there
Find out what you blew up first. A mini spool acts like welded spiders, so if you toasted a cross pin or the carrier itself, the same thing will happen with a mini spool.
Justin
Discussion Starter · #11 ·
Discussion Starter · #12 ·
I want to experience this for myself. Im against giving up weight and ground
clearance if I dont have to.
Discussion Starter · #14 ·
You can always put the stock tires back on. That would be hilarious.
I think Id rather drive a smart car then my bronco with 31's on it
and all that lift.
Yes True. I have to see whats broken first but Im throwing this idea around
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PWT%2D1822%2DLR&N=700+4294924929+4294908331+4294908330+4294925134+4294839047+4294918887+4294901314+115&autoview=sku
With the street driving I do it should be a good fit. That is as long as the
carrier isnt damaged.
Wait, you welded the diff and then blew it up, and you are thinking that there is a chance that the stock carrier is still ok? :banghead
Discussion Starter · #16 ·
This is all yet to be seen. I havent pulled the diff cover yet. Im thinking/hoping
its just the spider gears.
Thats the problem with welding the rear gears - Too much stress when driving on streets, if you were off road more that wouldn't happen..
So there's your answer, fix it, weld it, and wheel it!
Discussion Starter · #19 ·
I guess you didn't weld them to the carrier then.
No I ran a bead in between where the spider gears mesh, on both sides of
the carrier.
There was a guy on here who welded the entire carrier and spider gears
together into one big chunk. I think his is still together. Ill tell you though I
really enjoyed having so slip between the rear tires whatsoever. Didnt even
need 4 wheel on the beach.
Im really getting anxious now to see whats behind door number one (diff cover)
X why dont you look into a Aussie locker. There a little cheaper then the Powertrax and I have heard nothing but good things about them.
1 - 20 of 106 Posts
