All of a sudden my ABS light went on and a few minutes later the CE light came on, and then a few minutes after that my OD light started blinking. Tranny started shifting funny, speedo quit, cruise control quit. Man, I thought the whole Bronco was crapping out on me!! I took it to my local mechanic and after a while he called me and asked if I had pulled a trailer in the past few days. I had. He said the trailer lights must have had a short and blown the fuse and that fuse caused all of my problems. Hard to imagine.
yo PAPPY,
Yep, could be fuse in Power Distribution Box
Diagram in 96 Bronco & F-Series by Ford via thedieselstop.com @ http://www.thedieselstop.com/faq/9497faq/maint/stj/stji1002.htm
in cab's Fuse Box.
They travel a nice long path thru the Power Distribution Box to cab fuse block/trailer relay box to da 4WABS Control Module..and on and on
4WABS Wiring Diagram in 93-96
4WABS Control Module Overview; "...A new light truck 4-Wheel ABS was introduced as standard equipment on the 1993 Explorer and Bronco, and it was revised in 1994 on Broncos, requiring a different control module revision for 94-96 Broncos, compared to the original '93 Bronco module. The anti-lock brake electronic control module is located in the engine compartment behind the driver's side head lamp on a bracket mounted on the surface of the plastic fender apron. It is an on-board diagnostic, non-repairable unit consisting of two microprocessors and the necessary circuitry for their operation. These microprocessors are programmed identically. The anti-lock brake electronic control module monitors system operation during normal driving as well as during anti-lock braking. In addition, the anti-lock brake electronic control module provides a speed signal to the programmable speedometer/odometer module (PSOM)..." read more
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/280776
Trailer & Camper Wiring Diagrams for 94 & 96 Trucks
Source: by Ford via Steve83 (Steve, That dirty old truck) at SuperMotors.net
Fuse 17 Blown, Short Circuit The transmission control switch wiring may be misrouted causing a short in the steering column and a blown # 17 fuse. The following symptoms may be associated with this concern; Early shifts, Loss of power, Poor acceleration, 3-4 shift cycling, Transmission control light cycling ON/OFF or inoperative, Transmission control switch inoperative, Rear Anti-Lock Brake System (RABS) electronics (dash lights on, etc.) inoperative, Loss of instrumentation (tach, fuel gauge, etc.), Unable to read Self-Test codes (solid tone only)
Source: by miesk5 at FSB http://fullsizebronco.com/forum/showthread.php?p=2306552#post2306552
other Same symptoms info from other posts; hot links prob won't work even tho I did a direct C&P; so look for them here
http://fullsizebronco.com/forum/showthread.php?t=171136&page=2
Wow, thanks Miesk5 for all that info. I'm sending it to my mechanic. We only have 2 auto mechanics in Garden Valley so I am sure he will enjoy the read. I really appreciate it that you took the time to respond.
Pap
yw Pappy.
Was a Scan done for DTCs?
Also print is out here; in case the fuses are good.
This stuff;
There are abour 4 connectors from the ABS Sensor on the 8.8 thru the 4WABS Control Module & then up to da PSOM (Speedo/odometer) and then to the EEC/Cruise Control/ Overhead Console.
Is the Amber ABS Light lit all da time?
some tips;
PSOM Continuity Test Through 4WABS Control Module Connector in 93-96; "...jumper 14 to 21, & 39 to 22..." MIESK5 NOTE; See diagram. I did this on our 96; The 4WABS Control Module was toasted; 2 yard 4WABS Control Modules were also bad; NO RETURNS!
Source: by Steve83 (Steve, That dirty old truck) at http://www.fullsizebronco.com/forum/showthread.php?t=102436&highlight=psom+4wabs&page=2
He jumps out the 2 wires from the VSS Sensor to the PSOM and beyond... so it jumps the ckt thru the 4WABS Module instead of going thru the Module in order to discount the module if it's bad, which it was in my 96.
4WABS Connectors Diagrams for 93-96
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/vehicles/registry/media/280768
Wiring Diagram in 96 (similar to 92-95) & CHECK SPEED INPUT SIGNAL Test
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.superford.org/vehicles/registry/showmedia.php?id=95931
4WABS Component Locations; "...> Anti-Lock Hydraulic Control Unit (2C215) located in the front of the engine compartment on the left frame rail. > Anti-lock brake electronic control module located in the engine compartment behind the driver's side headlamp on a bracket mounted on the surface of the plastic fender apron. > Two front brake anti-lock sensors (2C204) are attached to the suspension knuckles. The front brake anti-lock sensor indicators (2C182) are pressed onto the backside of the rotors. > Rear axle speed sensor integrated into the rear axle housing. > Acceleration sensor attached to the left frame rail under the driver. > Stoplight switch (13480) located at the brake pedal (2455). > Main relay (14N089) located in the power distribution box. > Pump motor relay located in the power distribution box. > System diode located in the relay box mounted behind the power distribution box with the main relay. > Fuses for system power and the pump motor are both located in the power distribution box..."
or;
VSS Tone Ring Damage pics in a 95 8.8
Source: by sackman9975 at http://www.supermotors.net/registry/19344/67582
Tone Ring Inspection; "Take off the rear diff cover. Check the Ring Tone gear. It is located on the left hand side of the ring gear. Look to see if any of the teeth have been notched (from debris floating around in the diff.) Usually a spider gear. If the ring tone gear has been notched, it will need to be replaced to fix your speedo reading. Jack it up and rotate the tires to look for the teeth to be notched/broken/bent..."
Source: by Bighibbi at http://fullsizebronco.com/forum/showthread.php?t=59278&highlight=tone+ring
Pointer Waiver TSB 96-21-11 for 92-96; "...The speedometer needle may waver and/or a light surge may occur on some vehicles when speed control is used at highway speeds between 80-113 km/h (50-70 mph). This may be due to slight dents/chips in either the exciter ring or the Vehicle Speed Sensor (VSS) and air gaps between the VSS and the exciter ring..."
Source: by Ford via miesk5 at http://home.comcast.net/~miesk5/technical_service_bulletins.htm#PSOM Pointer Waiver TSB 96-21-11 for 92-96
yw, but the guys and Gals that take the time & effort to post-up the info in ther 1st place deserve thanks.
I merely act as a conduit; sometimes helping and a few times....
GL with it pappy
and if you get it scanned for Codes; post them here; or if in a hurry, look in my site and use the Search feature.. just type in the code
sometimes it is a PO code... so type it in as both
P0
P Zero
and PO
P Oh
it will show the Links..
Unless it's included in a Group such as P0442 in DTC P0440 thru P1441
