Call me crazy, but I happen to like to ABS, :whiteflag so I'd like to get mine working again. So far, I've done the following:
1. Pulled the code (24).
2. Checked fuses & relays. (note to self: that's why my trailer lights don't work, I'm missing the 3 relays!)
3. Disconnected the ECU, HCU, and pump motor connectors and cleaned them out (they weren't bad, but I used a Q-tip to get the little bit of dust out of there).
I'm kind of stuck now when it comes to measuring the circuits.
Chilton's says to "measure the resistance between pins 17 & 34."
However, I don't have a pin 34, because my '95 ABS ECU looks like this.
So if I skip D1 and move to D2, it says to "measure resistance between Pins 1 & 5 on the valve block". So, I assume that means measure the resistance on the component side (the side connected to the HCU). However, the only diagram I can find that shows the pin numbers is this one. Note the pin number guide in the text below. According to this, pin 1 is 532 (O/Y) and pin 5 is 498 (PK). Based on the description of code 24 (Isolation Valve right front shorted or open), shouldn't I be testing circuit 497 (W)? Is it possible that Steve83 has the pin numbers wrong? (blasphemy, I know
Looking at the Haynes manual, it recommends measuring the resistance on the component side of the "harness connector at the RABS valve" from pins 1 to 5, 4 to 5, and 5 to ground. (I assume that means the HCU side of the connector.) But again, that means measuring 532 (O/Y) to 498 (PK), 532 (O/Y) to 498 (PK), and 498 (PK) to ground respectively, if you go by the pin numbers from the above Steve83 link.
