1 - 1 of 1 Posts
OK...with all the talk of ABS lights and pulling codes...I decided to pull mine since my light is on. I thought I knew what the problem was (I bashed the Wheel Speed Sensor (front Drivers Side) when trying to remove the spindle once) so it was no biggie. Well I pulled the codes and am confused. This is the seq. I got
lllllll---l-l---lll-l---lll-ll---lll-lll---lll-lllllll---llllll-lllllll---lllllll-lllllll
the way I read this is:
7 Shorted Isolation Valve or Harness
11 Brake Light Switch Always Closed (This it true, cause my E-brake light never comes on)
31 Speed Sensor Open or Shorted (Left front Wheel) (again true the one I bashed)
32 Speed Sensor Open or Shorted (Right front Wheel)
33 Speed Sensor Open or Shorted (Rear Wheels)
37 Speed Sensor Open or Shorted (Rear Wheels)
67 Fluid Return Pump (runs all the time)
77 NO IDEA!
I had no ABS Light before the smashing of the Wheel Speed Sensor...and I'd like to replace it, but it's rusted in there. Need to get it to the shop to do this, cause I can't get the Spindle off with it on!
Anyway...could all of these be because of one bad sensor? I hope so.
1 - 1 of 1 Posts
