Ok i have a 1996 bronco 302 when i floor it it bogs if i either back off or slightly step in to the throttle it runs like a champ :rockonsoo i think its the tps sensor?? any thoughts
hmmm a leak could make it where it wont open the fuel regulator hmmmmWhat does a vacuum gauge tell you? See THIS
I do see that nowok my bad its a five speed
no ima run up to advance right now be back in 15 mins ill post codes :thumbupI do see that now
Anyway, do you have access to a code reader? And a vacuum leak is very plausible, as is a misfire. I had the same problem for both.
