1 - 9 of 9 Posts
Some people will believe anything... (Not saying you do, but they're out there)
How much does the acetone cost to get the better mileage? In the end, is it cheaper? How about after you replace a bunch of your fuel injection system because the solvent chewed everything up?
Can't be any worse then Sea Foam and that works fine, sort of the same principal isnt it maybe acetone is less expensive ~ :scratchhe
I'd be interested in what everyone else here has to say, I think I read that here some time ago IIRC.....................?
Thanks ~ :thumbup
Call an amberlamps!
Thanks ~ :thumbup
its only like 2.50 a container and your only supposed to use a small amount... Its cheap... a little goes a long way
Man with a Golden ticket
Didn't this just come up within the last few days? :scratchhe
Call an amberlamps!
My bad guys, When i searched i must have misspelled "acetone" and nothing came up.
BTY: Mythbusters proved that it acc. make MPG worse.
Doesn't work
I tried adding Acetone to my 1996 Bronco 5.8 Auto. I used the Acetone for five tanks of gas. My gas mileage got worse by 2 MPG.
1 - 9 of 9 Posts
