Now, I have some news. I just finished messing with some stuff on the truck. Six, you were right. I used that rod and it turned over. I assume that means it is the actuator? I had to jump it because of the battery problem. I also noticed that the interior lights are not working. The switched ones do, but not the coutesy lights. I got it running and left it on for about five mins. I stopped it, then let it sit for ten. I had to jump it again. I still have no clue what it could be. Don't give up yet, PLEASE.
Forgive the cut and paste broncrog
but I think I really am getting carpal;
T MAX
Had that same actuator rod assembly go on mine two Decembers ago in front of a Ford dealership in a town a long way from home. It was obvious it wanted Ford parts and wasn't taking no for an answer so it stranded me in front of a Ford dealer (damn unreasonable female Broncos !).
The next morning I was in the Bronco the whole time holding a trouble light and passing tools to the super friendly master mechanic who taught me more in 1/2 a day than a one month course on columns could have.
There is a couple of special tools and pullers for getting that piece(which is critical to allowing the key cranking fuction at the different angles the tilt can get into) out and back in.
The way he was in and outta that column and the way he used a pick tool was awe inspiring. I vowed then and there to get some quality pick tools when I got back home and I did.
MAJOR TIP****************** LISTEN UP ALL NON CRANKING BRONCOS
I had thought the coil had died and swapped in a new one before taking it to the dealer (who more than earned his way out of being called a stealership). He told me it would have started that night before if I had done this;
He turned the key onto crank(nothing happened), reached low on the column, just below the dash, and shoved his pick tool into the column and pulled down. That thing not only rolled over but it started.
I was half pissed that I could have driven home that night if I'd known this, but realized that there probably wasn't a better Ford mechanic on the planet to have replace that actuator rod assembly quicker and diagnose the $11 column switch either.
SO IN CONCLUSION REACH UNDER YOUR DASH AND PULL DOWN ON THAT COLUMN SWITCH ACTUATOR ROD(with the key on) AND SHE'LL LIKELY START RIGHT UP.
He told me yes the switches die but they can also "walk" up the column and and get so loose the rod coming down from the key will not actuate the column switch(it's also a sign the $11 switch is about to die).
He also recommended I change that pot metal actuator rod assembly (Ford # E9TZ*3E715*B, $16.32 CDN). This took him half an hour and if I'd been able to do it I estimate even after my install lesson would have taken me most of the day.
He also recognized my round copper contact disc on the column was getting worn out and that was probably the reason my cruise was no longer working. Man if they'd had one in stock I'd have had him chuck one in !
Also learned about a super fix on our coil plugs. Mine's wires were nearly broken off. Part #9111 socket is a brand new coil plug with two wires going into it that have to be 10 gauge (little re-engineering there Ford ?) and come with blue solderless butt connectors on the end of the 18" long wires.
That was real lucky breakdown dieing in front of that particular Ford dealer !
Hope this helps y'all !
Sixlitre
