1 - 4 of 4 Posts
Is there anything else I need besides whats in there?
Brand: Pro Comp
Product Line: Explorer Pro Comp Add-A-Leaf Kits
Universal: No
Add a Leaf Style: Short
Leaf Spring Width: 2.36 in.
U-Bolts Included: No
Leaf Pack Clamp Included: No
Center Pin Included: Yes
Quantity: Sold as a pair.
Add-A-Leafs, Short-Style, 2.36 in. Width, Chevy/GMC/Dodge/Ford/Jeep/Mitsubishi/Nissan/Rover/Toyota, Pair
* Check to make sure this part fits your application
Add height without an overhaul.
These Pro Comp Add-A-Leaf kits are the perfect way to add 1 1/2 in. to 2 1/2 in. of ride height to your vehicle without completely overhauling your suspension. Each kit includes two single leaves and new centering bolts.
I used the add a leafs when I first put on my 4" lift and I really didn't need anything else. We bought a long threaded rod to initionally set them up, but that was it.
i bought the skyjacker add a leaf and coil lift springs. i used the factory center pin. same amount of lift yours has. the clamp that goes around the leaves at the front of the setup, be carefull when spreading those, i broke one and welded it back. its not a big deal just that much more stuff you have to deal with.
1 - 4 of 4 Posts
