1 - 20 of 26 Posts
1995 XLT SAS w D44 and D60 rear
After my first night experience in Moab a couple of years ago I decided that more light would be good. After a bunch of ideas I ended up going this way.
Don't worry they are not blue
Motor vehicle Automotive tire Hood Automotive lighting Automotive design
Spent a lot of time getting the old wiring straightened out some and built a rail for relays
Motor vehicle Automotive exterior Electrical wiring Gas Automotive tire
Motor vehicle Hood Automotive tire Automotive exterior Vehicle
Cut the grill and added aluminum support around mounting points
Automotive tire Grille Bumper Automotive exterior Gas
Hood Automotive lighting Motor vehicle Automotive tire Bumper
Hood Motor vehicle Waste container Automotive lighting Automotive tire
Grille Vehicle Vehicle registration plate Automotive tire Hood
Automotive lighting Hood Automotive tire Motor vehicle Bumper
Finally look almost like I had hoped
Car Vehicle Grille Automotive lighting Hood
Automotive parking light Tire Grille Automotive tire Automotive lighting
That was a long night on one of the hardest trails out there to navigate in the dark….
Looks good though (y)
Reactions: BigBlue 94
Moderator
Was that when Tim's tensioner broke??
I was out recently here in KS with @HarryGnuts on a seriously back-winding forest trail, in the dark, when it started pouring rain. Extra light was key for finding our way back so I could get out of the gator and in his dry bronco.
I added a brush guard on my bronco so had to move the lights that were tucked in my grille. I added a pair of led cubes too.
Tire Vehicle Wheel Car Automotive tire
Moderator
It was that adventure. I had a bar just like that on my 81.
I think i was stuck at camp without a harmonic balancer for that one...
This bar came from the junkyard. It was homemade by someone, and will take on anything shy of a bull moose. Those cross tubes are like 5/16 wall steel tube! Had to cut the lowest one off as it interfered with my receiver. Just that cut off tube was like 25 pounds.
The Tennessee Warden
96 XL, built 357W, E4OD, BW1356, D44 SAS, 4.56 gears
I have all the lights I’ll possibly need now lol. I do have one more open rocker switch though - maybe I’ll add an interior light in the back cargo area where the compressor is.
Discussion Starter · #9 ·
What does your switch panel look like?
Discussion Starter · #13 · (Edited)
Both are more concise then mine. I have a few switched here a few there.
OBA and Winch on the left
Vehicle Gauge Car Motor vehicle Steering wheel
Lights and trailer brake lower right
Vehicle Plant Steering wheel Steering part Car
ARB and cooling fan upper right Damn those are more crooked in pictures than in real life:eek:
Car Vehicle Motor vehicle Radio Steering part
An I still need a switch for my transmission cooler fan somewhere.
Moderator
Mine are for (L to R): main fan, aux fan, hood heat extraction fan, OBA, fog lights, spot lights, subwoofer level, and electric fuel pump.
The left four are like 1.5" long toggles.
1991 XLT. 5.0, E4OD, manual transfer case, 4.10 LS, factory manual lockouts
I kind of like these but REALY do not want to spend $100+ on one
That specific unit is 8 circuit, available on Amazon for 120 bucks. A 6 circuit unit by same company is 90.
92 Bronco, 408 Stroker, 6R80, 4" lift, 9 inch, ARB lockers, 4.56 gears, Bassani exhaust
Nice. Will you take me wheeling in Moab when I get mine done?
Moderator
...Bronco Safari 2022 is coming up in late April. There will be a few of us out there im sure. I plan to be.
1 - 20 of 26 Posts
