My question is has anyone replaced the reservoir on the back of a saginaw pump to a nipple style so that I can run an additional remote reservoir for my ram assist setup.
The reason for the sudden question is that I just picked up a real York bracket (2nd hand BroncoAir bracket) to replace my home made job, My current homemade bracket raises the York way up and the nice one from BroncoAir is much lower, and will be right on top of the power steering cap.
I currently have what I consider a temporary ******* radiator hose extending the power steering neck in order to run more power steering fluid for my ram assist and would like to finalize my setup to get rid of the mess that tends to happen when iam off camber and I have Power steering fluid spilling out the top of the hose.
Has anyone done this? I already pulled a remote reservoir from a mini van, and i suspect I could pull a nipple reservoir off a saginaw from the junkyard to replace the one i have now.
A bit more info, I have the Cardone HD pump that uses the stock bracket, so not the van bracket type pump if that matters... suggestions? Is this a straight forward swap? any special tools needed?
I guess another solution would be to change out the cap if they have a nipple cap? maybe another suggestion from the bright engineers that litter this fine establishment?
