1 - 2 of 2 Posts
So I installed the adjustable camber bushings.With springs.The bushings are maxed out at 2 3/4 deg,yet i still need a couple more degrees...My camber is easily positive at least 2 degrees..How do I get the extra degrees?
Discussion Starter · #2 ·
drop brackets...I installed what the Volusia county cop I bought these springs from on clist said was front lvl springs.No way are they.
I have installed AAL in the rear and these springs brought the front up past the rear about 3"..Overall a 4-6" raise in the front..
Im thinking the only way these will work is with brackets.
Screw it I ordered 2" spacer and ill install with the stock springs n be done with it..
1 - 2 of 2 Posts
