1 - 20 of 103 Posts
Hey guys i fabricated a intake tube for my 96 351. and i wanted to put a cone filter at the end of the mass air flow sensor. but the only thing is the temperture sensor on air box it self. what would i do with that plug, if it is not plugged in then the check engine light will come on. so if u have any sollutions i would like to know!
Wrenching for a Livin'
Pep Boys (a ricers three best friends) sells some adapter plates, tubing and filters that can make it work at a resonable price. I was looking at some lost week for my comanche
Very interesting reading. Just like you said, K&N replacement filter with insulation tape around stock airbox= big difference! Has anybody else tried this? Results? I may have to give it a shot
Who needs oil anyways....
Steve83 said:
It works fine for me. :shrug Did anyone try pressing the *RESULTS* button & then any of the components on that page???
Worked here too. Nice link!
bryanrevans said:
insulation tape around the seams of stock assembly???And thats it???
Check the link out. Everything from the intake on the core support to the TB is wrapped.
what did yall use for insulating material? that stuff they used seems a bit pricy to me. anyone tried peal and seal? lol it might be the anser to every problem on a bronco. lol
also my intake tubes have ribs on the outside so should i try to get the insulating stuf to fallow the ribs or just stretch over them? there should be pics on my supermotors if that sounds funny to yall.
Steve83 said:
I think the stuff I used was ~$3/15'. Spiral-wrap the flexible sections so they can still flex.
Where can the wrap be purchased? What is it called and who is it made by exactly? I already have the K&N replacement filter, if I just need to insulate the intake system for a noticable improvement, then count me in.
ASM
Yes, where did you get it, and what is it called?
Steve- How much of a difference did it make for you? (MPG, Temp., etc.)
Banned
I don't remember the name or brand, but it's just foil-faced closed-cell (neoprene) foam weatherstrip tape 1/8" x 2". I got it at some regional chain hardware store, but I'm sure you can find it anywhere.
I didn't try to measure hp/mpg before or after, but there's a long steep interstate bridge in my hometown, and I was always VERY aware of my speed (or lack of it) when I crested it. Since I found the tape on the other side, I got to see my speed that day without, and then an hour or so later (basically the same conditions) with the tape, and I was holding ~5mph higher than before. I noticed an difference throughout the next couple of weeks over what it had been before, so I know there was a difference.
My K&N test was the same thing: over the bridge to buy it; back with it installed.
After reading Project MPG I decided to give it a try. I used insulation instead of the tape. It's bubble wrap with an aluminum foil on both sides. Total cost was $17.00 for a 16"x25' roll of insulation and $7.00 for a roll of 2" aluminum tape. The pictures are links to more pictures of the insulating.
1 - 20 of 103 Posts
