I think it's the clock spring.
~~~~~~~~~Originally Posted by bigric
OK, here's the entire air bag code set:
— No Air Bag Indicator — Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
— Continuous Air Bag Indicator — Air Bag Diagnostic Monitor Disconnected or Inoperative
12 Low Battery Voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse — Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply — Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
— Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
Yep.I have the same error popping up. Where you ever able to find what was causing it?
I'm going to do some investigating tomorrow in the daylight, but if you could point me in a general area that'd be great!:thumbup
The wires all look fine until i popped off the grill for a closer inspection found the real problem....besides that leaf that is lodged in thereSource: by Chilton via autozone.com
Check: connector first and see if it or wire strands, etc. is corroded or disconnected; damaged sensor; corrosion or damage @he sensor mounting surface.
Yes, but I posted the most likely causes for his first; if not the sensor/conn/wiring, then the TS goes back along w/da wires to da Mod.; as shown in Steve's diagrams(s)huh? when i got that code it was the module, somehow i got a leak inside that let water into the little blue box under the dash behind the door buzzer, i took it out cracked it open and it was char black, the circuit board was fried, so i left it out, i could probly get it in a j/y but no bother, did you get yours fingered out?
