I have a 95 Eddie with towing package. Alternator went out several years ago. Replaced it with a 95 amp from local auto supply. My Question, what is the correct alternator amperage for a 95 Eddie with a towing package ?
Tire Wheel Car Vehicle Sky
ith a towing package? I
aka: kemicalburns
The 95 amp you have. You can upgrade to a 130 amp with no wiring changes necessary but advised.
Reactions: jermil01
Yo Jay,
Welcome!
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
1995 Bronco Dealer Brochure @ 1995 Ford Bronco
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (50 non-padded posts required to participate, due to scammers who preyed on our members).
Our Forum FAQs includes for example, How to:Use Search, Post pics and more tips
See How to add your Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Baba Looey's Favorite FSB Links (lots and lots of tech links)
... Includes such as, How do I fix my back window?
Take time to participate in our next Full-Size of the Year & later in the next Full-Size of the Month Contest @ Voting
You will get ideas by those competing.
Prizes are awarded to the winner!; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; and a years worth of premium FSB membership.
Al
1995 5.8, 2.5" Rough Country Lift, Extended RA's, 4.10's, 33" BFG's
Broncos came with 95 amp alternators no matter the options. If you want more amperage get a 130 amp alternator for a 1995 Explorer it will bolt up with no mods
Reactions: miesk5
95 5.8L MAF XLT, Hedman Shorties/MF SS Y & Muff, E4OD, Man hubs, KYB Quads, 31x10.5x15, 304K miles
Yup 130amp Alternator in mine and all is perfect now, no flickering or loss of voltage at idle, Rock solid. You won't be disappointed, the Stock Alt was/is 95amps, it's just not enough, marginal at best on my 95 with Towing Package.....
FYI: you can ID them by looking at the holes.
4 holes = 95A
2 holes = 130A
Image courtesy of Google
Depending on how you wire it up and where the additional amperage will be directed, you may want to consider adding a 175A mega fuse holder or simply adding the OEM fuseable link out of the same application that the alt came out of.
Even the original fuseable link from a 95A truck won't be a problem UNLESS you draw that extra power THROUGH it.
