#1 Asshole
Ok I have a 91 bko 4x4 5.0l ho e4od i just put a used e4od in it it shifts good and everything is pretty well satisfactory except for when I put it in drive it is in neutral until i slam the shifter as far as I can without going to second gear then it is fine. If you hit a bump it will neutral out. I have adjusted the mpls nothing changed so I bought a new mpls and adjusted it nothing changed. What would the problem be? possible a valve body repair or possible replace?
#1 Asshole
checked them and installed dielectrical grease too no change
#1 Asshole
anybody else have any ideas about this? please help!
#1 Asshole
Someone here has gotta have some kind of wisdom about this one. I changed mlps(damn chinese parts) today the one on it was bad. Found out by accident can't get koer codes tracking stuff down it's good now. no change.
