1 - 2 of 2 Posts
Buddy of mine was rear ended in his 90 f150 (2wd long bed 5.0). Ever since he has had no power windows or door locks, no radio, no dash lights. There is almost no damage to the truck and the fuses check out. He also sees no loose wires. I am positive it is a ground (from experience) but I cannot go look at the truck for awhile. Any ideas I can shoot his way? Thanks.
IIRC those are all on one or two circuits. Pull the fuses and check for 12v across the fuse terminals. Then you know whether to search upstream or downstream. So many things are affected that it should be easy because they share common wiring in so few areas.
1 - 2 of 2 Posts
