1 - 20 of 25 Posts
Charlie don't surf..
'92 Ford Bronco XLT
Any pics of knuckle removal/installation??
The knuckles are giving me a real PITA. I have soaked the castle nuts in PB blaster, but still can't move the inner castle nut..Do I need to heat it or just apply more muscle. I've used a half in breaker bar with added leverage from a length of pipe and still nothing. Thanks.
Lurker
They shouldn't be that tight, especially the castle nut. I used the correct size socket and a Hi-lift jack handle as a breaker bar and they came off. Good luck , I know it can get frustrating.
I would suggest having the axle on the truck before installing the new joints.
'92 Ford Bronco XLT
I wish I could have the axle under my rig before doing the ball joints, but it's not going to happen. There's still way too much to do on it and I want to get the axle completely cleaned before I do the swap. I'll just hit those nuts with some more PB and hopefully that will do the trick.
quit with the pb, it doesnt werk.i heated mine red hot ,waited for them to cool and beta the living hell outa them. after a couple houres i had both knuckles off.a grinder helps too.
'92 Ford Bronco XLT
Okay, I got the knuckles off of both side, things are progressing a lot more smoothly now..
Hit it top and bottom with the separator, and..
ya mine looks like hell inside the tubes too.i just ran a rag wit laquer thinner on it thru and took care of most of it
'92 Ford Bronco XLT
Discussion Starter · #8 ·
I think I'm going to get the axle hot tanked. It shouldn't cost that much.
'92 Ford Bronco XLT
Discussion Starter · #10 ·
Good question, I need to find a place around here that does that sort of thing, any ideas??
www.easttn4x4.com
I know machine shops do engine blocks, but an axle? Maybe they can if their vat is big enough. I found an article about making your own once, but that's been awhile. It wasn't to bad to make useing an old cast iron bath tub from what I remember.
'92 Ford Bronco XLT
Discussion Starter · #12 ·
Gub Ni, thanks for the heads up.I called around to a few machine shops hear in town, found one that will be able to do it. The guy said it would only be $10 bucks to run through the tank. Not a bad deal.
'92 Ford Bronco XLT
Discussion Starter · #14 ·
nu_bronco said:
Can anyone tell me what a "hot tank" is? Do they just dunk your part in a vat of something that cleans it? Also, what all will this remove, ie paint, rust, or just dirt? Thanks.
That's pretty much what it does. From what I understand it is some sort of heated chemical solution that removes all of the crap, dirt and so forth. I am not sure about rust.
'92 Ford Bronco XLT
Discussion Starter · #15 ·
Installing the balljoint
I hate to drudge this up again, but I am now trying to reinstall the new ball joints on the knuckles. The manual says to start with the lower ball joint first, what am I doing wrong here?? do I need to push the ball joint in the same way they push out?? Help..
This is what I tried to do with no success.
I know I must have something backwards here.
'92 Ford Bronco XLT
Discussion Starter · #17 ·
When I pushed them out, I pushed from the bottom up...but it looks like there is a bit of a difference between the old ball joints and the new ones..The bottom one definitely has to go in first per the manual. I'm pretty sure I have it the right way, installing the lower ball joint in the lower hole..I'll double check when I get home today, it would be f**ked up if I was trying to put the wrong one in.. :twak :brownbag
'92 Ford Bronco XLT
Discussion Starter · #19 ·
Do you think a little bearing grease would help?? Or would that be bad?
1 - 20 of 25 Posts
