I just got done with a mini marathon of Bronco wrenching that I've been putting off since August. I replaced the fuel injectors, fuel pressure regulator, valve cover gaskets, motor mounts, etc. I found that the upper manifold is cracked above the bolt near cylinder #8. I tried the JB weld route for a temporary solution, but while torquing the bolts to 16 ft/lb it let go (It held fine at 12 ft/lb). For now I smeared some RTV over the crack just to get the truck going.
The diaphram on the fuel pressure regulator had ruptured and fuel was flowing into the manifold, making the truck run rich enough that it wouldn't idle. This might explain why it failed emissions in August :doh0715:
Does anyone local have an extra upper manifold for a 302? Since this one broke should I look for something else to replace it with?
Thanks,
Mitch
Thanks,
Mitch
