its made by agr. its called the ford super pump. it comes tapped for hydroboost and creates a whopping 1500 psi and 4 gpm. sounds like a great pump but i have heard too many negative things about agr. so what's the verdict, anyone have any experience with this pump or agr pumps or gear boxs in general?
Why not just switch over to the Saginaw pump (if it can be done on a 96)?
i guess because i figure if there is something better, why not have it? also, like i mentioned it's setup for hydraboost. The reg sag is not. I would have to tap into it. So if there is a great pump already set up for it, it sounds like a winner to me!
I'm one the does not recomend their boxes. Redhead boxes are everything AGR claims to be. It just sucks I bought AGR first. based on that, I wouldnt try the pump.
noted. Thanks for the input. Anyone think otherwise of agr? or have another option.
You can get a 1996 F350/f450 sag pump with 2 returns. only thing about the hydroboost pumps is that the are 2 returns, one is for the gear box and the other return is for the hydroboost. you can also go with a few other years as well, not sure which.
