just pick one up from the junkyard.You also have to figure out the kickdown linkage for the C6. You also have to run a vacuum line for the c6, but that is super easy after you figure out the kickdown.
I guess it's not really relative to the thread but unless it's been swapped, the trans in your 94 is not an AOD. Though it is indeed an automatic overdrive, it is an E4OD which is not the same.My AOD went out in my 94 bronco, so im gunna run a c6/np205 with twin sticks. if i were you i would do the same thing, but its up to you.
My truck is not an automatic…the guy that owned it before me swapped it, sorry for the confusionI guess it's not really relative to the thread but unless it's been swapped, the trans in your 94 is not an AOD. Though it is indeed an automatic overdrive, it is an E4OD which is not the same.
