1987 Bronco, 302, AOD
My transmision has been slipping only in first gear but not everytime. When you give it gas and let off you can hear it spin and then it clunks when engages again. Does this sound like a torque converter problem or something more internal. The transmission was said to be recently rebiult according to the previous owner. It had a crack that was leaking fliud and i fixed it with a dremal and some jb weld. Then I changed the filter and fliud. The fluid looked a little dirty and the bottom of the pan had a thin film of gray on it, which i did not know if it was normal or not.
