1 - 2 of 2 Posts
After reading a post from fireguy where he shows how he uses a paintball tank for his ARB, it makes me have a few questions about my setup. I'll be using a tank too, not a paintball one, but my solenoid valve is a little dfferent than the ARB one. It came with my used dana 44 with ARB installed.
The solenoid works fine, but I have a question about how to bleed the line. Notice the brass plug in the pic.
It screws into the solenoid.
When I take it off it will bleed excess air in the line after the solenoid goes closed, but I obviously don't want to just leave an exposed hole. How does the stock ARB solenoid bleed the air? Is there sa one way air valve I could screw in there? Anything special about the ARB air line? I need to replace mine and would like to just get it at a store for cheap. Diameter?
That is the old style ARB solenoid. The "brass plug" is where the air is discharged when you turn off the locker, and that plug is actually a filter to keep crap from getting in. Leave it there.
The blue airline for the locker goes in the orange plug and it is 5mm.
1 - 2 of 2 Posts
