Does anyone know if the 2wd and 4wd oil pans were the same for the 302? Thanks
I didn't think that there was a difference, turns out I was right...jb77714 said:theres a 2wd and 4wd oilpan??
So what you're saying here is that a TTB front end will bolt up to a 4x2 truck frame?RTM said:Keep in mind that a 4x2 truck can be converted into a 4x4 truck using the same frame where as 79 and earlier this is not the case.
Cool! The only thing I really didn't like about this truck (besides it having a bad motor) was that it is 2wd. I thought I was just going to have to SAS it, although that seems like a better option than putting in a TTB only to SAS at a later time.RTM said:YEP!
79 and earlier were front sump pans, from what I recall. I know the 460 was a front sump pan in my buddys 79 460 truck. Of course this is in a 4x2 truck not a 4x4 as 79 and ealry trucks used sepereate frames from 4x2 to 4x4.waltman said:A truck is a truck is a truck. The only time you should wonder if an oil pan will work is if you going from a car to a truck or visa versa...as far as I know.
