1 - 8 of 8 Posts
Question is; are the factory gauges on a 95 bronco replaceable, like the oil pressure or would you have to replace the cluster? Yes I know there not very accurate, however the Foxy Lady wants Her Bronco fixed!! rather than hang a real one on:banghead. I did ground out the wire thats goes to the sender and it appears gauge is bad, would not go to high, just wiggle a little, far to the left. Thanks
Thanks Red, I think I'll try it. Hope taking the cluster out and removing the gauge isn't to difficult, hate to destroy it.
the gauge is only an indication that there is enough oil to fill up the oil passage. Do a search and you will find a replacement by steve 83 for a real gauge, not one that goes to the a in normal. my truck had a hole in the oilpan and the gauge said normal even though the valves were clacking. Want to see the photo of my engine on a hoist? My old engine anyway. its a good time to fix it.
i was going to replace my stock gauges with aftermarket ones, but it just seemed like too much of a pain. the stock gauges are wired with a film that would be a pain in the butt to cut around to put the aftermarket gauges in the same place.
yo!
I was thinking...of buying one of those Trans Am hood mounted (tach) pods and using it for an oil press gauge (mech); so as to keep tubing out of cab.
There was a line item for da pod in year-one, but it was discontinued...
1 - 8 of 8 Posts
