I'm planning a modest upgrade, and have decided to take Gacknar's suggestion on increasing power. 1. Gears, 2. Intake, and 3. Exhaust.
I'm having the tranny rebuilt a little beefier to withstand the strain of the extra torque a little better, and the 4.56 gears go in right after the trans is done. For the intake i'm going with the Edelbrock 3881, a modest upgrade at a modest price. But, it is set up to receive the standard dual throttle body. And, since I picked up a complete stock MAF set up from a 95 BKO, I think I'm set up for parts 1 & 2. As far as exhaust pipes go, the headers will be determined based on the exhaust heads I go with, and the plumbing will be limited by the Carb authorized cat which current look to be a 2.5 in/out.
Being limited by California's emission laws, I'm required to use exhaust heads that have a CARB EO# or are listed by the manufacture as the stock replacement for the OEM part. :banghead The 94-95 Cobra and Lightning heads are the only ones that seem to be taped and drilled for California emissions. All the heads with an E0# seem to run in the $1200-2000 range per set. But, for somewhere around $400-500, I can find a used Lightning block & heads. Or, for around $1600, I can find a rebuilt Lightning.
So, rather than buy the expensive aftermarket heads, I'm thinking of going with the used Lightning. Which brings me back to the original question, are the Cobra and Lightning heads the same? If not I'm limited to only finding the old Lightning heads. And, finally how much better would the Lightning Head be on a 95 roller block versus my 90 flat tappet block. I'd be using something like a Comp Cam 35-255-5 vs the stock cam.:rockon
