1 - 9 of 9 Posts
Hello all, I bought a Curt 14001 class 4 hitch to install on my 96 bronco, however it is too wide to fit between the leaf spring hangars and the holes they tell you to use for going over the stock factory rivets to position the hitch are no way close to fitting as well. Anyone else come across this issue before? I'm not sure if the hitch was manufactured wrong from curt or not. It appears that I have about 37 3/8" width between the hangars and the curt hitch is about 37 3/4" wide.
i had to trim mine a little bit here to get it to fit. maybe on both sides? however, it didn't take much. and once i got it aligned with 2 bolts on each side i was able to tighten them down in steps to raise it up evenly.
that's where a second set of hands would be very useful.
162456
Thanks for the replies everyone, work has me traveling all this week so I'll try again come this weekend
1 - 9 of 9 Posts
