1 - 2 of 2 Posts
Yes I searched... I picked up a 130 amp 3g from a 98 contour today for cheap and in really good shape. Only thing is the regulator plug on the thing is smaller and more square than the one on the 95 amp alt currently on the bronco, which as you know is kind of "D" shaped. Are regulators Amp rating specific or can I just swap the old one off on my 95 amp 3g to the new 130 amp 3g so the plug is correct???. Also, the pulley on the 130 ampo from the contour maeasures 2 1/4 inches across, whereas the one on the bronco measures 2 3/4 inches across. Thoughts about using the smaller pulley thats on the 130 amp alt or should I change it out? I know Ill have to get a different size serp belt. I'm ready to do this in the morning.. thanks in advance for your reply
1 - 2 of 2 Posts
