:banghead ok i need some help, cant figure out how to get the
auto hubs off my 95, got the outer cap off but there is that inner
cap thing, cant turn it, pull it, dont see any snap rings, so whats
next!? Ive got a really annoying squeak/squeal i believe is coming from inside the wheel bearing/hub/ somethin in there area but
cant get there. while Im here the squeak is rubber sounding
especially after brakes are hot, any thoughts, can here something
rubber hangin up. anyway if anyone can help me get the hubs off i'd be really realy apreciative thanks!!!!!
no i couldnt tell anything was even there, i'll look again and try using a pick in there, thanks, n e thing else? all i see is a big cap lookin thing......... thanx
If I am correct you are having a problem with that first ring. I had the same deal. Its hard to see but its there up in the edge of the hub. It has nothing to grab on to but has a gap in the ring. Look close. Go in your house and get your ice pick. Ice pick seems kind of flimsy but once you get it behind that ring it just pops out and there is nothing to it. Once you get the first one out you will see.
