1 - 8 of 8 Posts
Getting ready to swap back over to an auto tranny from my 435. I recently twin sticked the 205 on the 435. When I swap in the auto can I just swap t-cases or is the input diffrent??
Slim
So you want to swap to the C6, but keep the same t-case because its twin sticked? Should'nt have a problem, the 205 will bolt behind a C6 or NP435.
Retired
Slim is the T-case a short tail shaft the was mated to a NP-203 or was it originally mated to a NP-205? Either way it can be done but if it was mated with a NP-203 you will have to shave the corner of the pan a little to clear the front CV joint.;)
Sweet ! Thanks fellas!
Both tranny's originally came with 205's. So It sounds like I should be ok:chili:
Thanks Dale!
1 - 8 of 8 Posts
