Hey guys i am in the middle of my dana 60 front coil swap and installed my extended arms, well my problem came from installing them and their mounts on my huge angled driveway so my Front axle walked around and is now not where it is supossed to be.
i used a plum bob, now that it is on level ground, set it at ride height with the coils removed, and found from the centerline on the upper frame coil bucket, and the center of the lower bucket are off on the driverside by what seems to be 2 inches, and 3.25 in. on the passengerside.
My question is on you alls trucks with lifts or stock does the center of the lower coil bucket line directly up with the center of the upper? i would think this to be true, but just wanna make sure before i move my mounts one last time, tomorrow.
Discussion Starter · #2 ·
can someone at least go look at there truck and see if the upper and lower buckets line up directly just by sight.
They look like they line up to me.
thanks thats what i figured. problem is now fixed
