Look at the second sticky topic in the 1980-'96 Bronco forum. It will be everything you want to know and then some. Do it when you'll have time to read through it all. Personally I do not know if 3.08s can do it for 33s.robbiedog said:OK guys, I finally have question. According to the tag on my rear axle, it has 3.08 gears and is an 8.8. Are these gears compatible with 33 inch tires?
Thanks.
I personally wouldnt run that setup. Just take a look at the sticky.robbiedog said:OK guys, I finally have question. According to the tag on my rear axle, it has 3.08 gears and is an 8.8. Are these gears compatible with 33 inch tires?
Thanks.
Nope.robbiedog said:Are these gears compatible with 33 inch tires?
BOOM!!!!!!!! Aw, man!Gacknar said:Nope.
If you put those tires on with those gears your engine will blow up the next time you try to start it.
J/K :histerica
Campatable, yea you can drive on them.
Recomended, no.
