1 - 19 of 19 Posts
I'm in FL and will ship. I prefer Paypal, but also accept cash, certified check, and money orders. All of the parts listed are in good, useable condition and are used unless otherwise noted. Please note that I don't have pics of these items, but guarentee them to be as described or better.
7* Poly C-Bushings $15 shipped
Hi-Pinion Dana 44 housing w/bearing caps and diff cover, no outers, carrier, gears, steering, shafts, etc. Has weld on wedges, nice shape, perfect for a project axle or coverting to full width, from a 1976 Ford F150, BOM is 603808. $75
Ford radius arms from a 78 F150, nice shape, no bends $50+shipping
78-79 F150/FSB radius arm brackets, perfect for SAS $50 shipped
HP D44 4.09 gears(ring & pinion), need to be cleaned before use, pinion bearings also included SOLD
HP D44 3.54 gears(ring & pinion), used, but nice, pinion bearings are included $15 shipped
3.92+ D44 carrier with spider gears still installed SOLD
D44 spider gears and I have two sets GONE
Ford D44 stub shafts(I have two) $20ea+shipping
Ford D44 short side inner axle shaft, will fit any full width Ford Dana 44 from 74-79 SOLD
76-79 Ford disc brake caliper brackets $45 shipped
D44 cover with high fill plug. Needs to be cleaned and painted otherwise ready to go SOLD.
Radius arm brackets from a 76? Ford 2wd/4wd? $25 shipped
1 pair of 6x5.5 lug pattern D44 hubs(Chevy, Jeep, Toyota, Nissan bolt pattern)no rotors or wheel studs included, nice shape SOLD
1986 Waggy front Dana 44 assembly, fully rebuilt using top quality components. 0 miles on this axle since rebuild.
WMS ~ 61.5, pumpkin on driver side(driver's side drop)
4.88 Yukon gears - 0 miles, brand new
3.92+ carrier
Aussie Locker
Warn manual hubs and a set of drive flanges(caps, spacers, slugs)
Professionally installed gears using Yukon install kit
Flat top knuckles with tall WFO hi-steer arms on both sides
Pro grade Spicer ball joints
All new bearings and seals throughout
Small bearing spindles with 5x5.5 lug pattern outers
Axle shafts filled with Spicer u-joints
DOM tie rod using Chevy 1 ton TREs
All bracketry removed ready for links or SOA
Cleaned and painted with black Rustoleum
All new brake pads, calipers, etc
Will include spring plates and u-bolts if you plan on using leaf springs with it
You can't build an axle like this for what I'm selling it for.
Will not part out this axle
$1200obo
Formerly vt89gtvert
pm sent on the carrier
Damn you doba, fist on Pirate, now you beat me to something here as well. Second in line for the carrier.
Doba, replied to your PM. You're second for the carrier.
vt89gtvert, you're third for the carrier.
Dibs on 44 HD Housing I'm sending you a pm now.
Thanks
3.92+ carrier and 4.09 gears are sold.
A lot of good stuff here guys/gals and I need it sold.
Short side inner axle shaft is sold.
Still have a bunch of stub shafts and the other stuff. Who needs trail spares?????
Discussion Starter · #8 ·
Edit, reference the HD D44 housing I am now including the inner axle shafts since they are specific to this axle. 77.5-79 HD D44's have different inner shafts than standard F150HP D44s. I have those shafts and they will go with the housing. Price has been adjusted to reflect this.
I also have Ford stub shafts if you plan on using Ford outers with the axle.
1 - 19 of 19 Posts
