1 - 20 of 35 Posts
Designated Tranny Killer
I searched and came up empty.
This is a stupid question but i run stock suspension and wheels and want to run 33-12.5's. I want to backspace so they don't rub at all. How do I back space, where do i get a kit for it, and how much is needed.:banghead
Administrator
back space is actually the measurement from the edge of the rim to the center portion of the rim where it bolts to the vehicle...only way of changing that would be with spacers or custom wheels...
FSB warrior
There is no way to safely remove ALL rubbing of 33's but drawing out your steering stops will help. Less backspacing will put your tires sticking way out, may get you in trouble with the law, and it puts a larger strain on your wheel bearings and BJ's.
I have no clue what you mean you can call me an idiot now if you want.:brownbag :banghead
o[|||]o
There is basically a bolt on each steering knuckle.. turn your steering wheel to full turn, and you will see the bolt hitting the axle housing. When you adjust this bolt, it allows for more or less turn radius. In other words, you would have to decrease your turning radius some to compensate, but turning that bolt out some.
FSB warrior
The stops: Cut your steering the the right all the way, get out of truck and look where your axle is straight and your knuckle is pointing about 45* to the right. There should be a bolt with about a 3/4" head on it sticking out maybe 1/4" if you loosen them up on both sides it will stop your wheel earlier, therefore probably keeping you from rubbing, but you wont be able to turn as tight.
Stick out further: Look down while watching Rosann barr on TV, now look down while watching porn.... thats sticking out further
The law: Guys who where blue/black uniforms and drive Crown Vics. They have pretty blue and red lights that flash on top sometimes.
Larger strain on BJ's and Wheelbearings: Cantiliever effect, loosen rusty bolt with 4" long wrench, loosen same rusty bolt with 1/2" breaker bar, 17" long and a 3 foot pipe on the end; puts more torque to the bolt in the center doesnt it??? This isn't that big of a deal because 33's arent that big though.
okay i gotcha now
thanks guys
and so what you are really saying is all i have to to is adjust the steering nuckle??
how do i off set my rims ??????
FSB warrior
buy new ones, or spacers. Spacers are extremely dangerous, 50x moreso then lift blocks.
oh it stays stock then
FSB warrior
Adjust the bolts out to a comprimising amount of rub and a some amount of turn and be done with it then. I just don't turn my wheels that far and pull into parking spots accordingly.
Discussion Starter #12
that should be good then thanks yall
Engineer
Get some new wheels mine have 4" backspacing I think. They dont rub on the sway bar or radius arms but I had to trim the fenders
Discussion Starter #14
todd where did you get the backspaced rims and how much if you don't mind
Engineer
Ebay, had no clue what they were when i got them, actually I dont even know what kind they are
R94BroncoXLT said:
My rims have a 4.5 in back spacing and I have never rubbed the radius arms or the sway bar W/ 33" X 12.5 or 35" X 12.5 tires
On stock suspension?
Who needs oil anyways....
No, he has a 4" lift listed in his sig.
Engineer
+1 but i rub on the top of the fenders at full flex
1 - 20 of 35 Posts
