I have a 78 Bronco w/ a '73 460. Having problems with it backfiring through the carburator (Edelbrock 750). Timing is set a 10Btc, idle 800rpm. Distributor and ignition seem to be good. Any suggestions? thanks much.
But what does mine say?
I'd back the timing off a lil, and then bring it up until just before it backfires. Just be careful. Where in KY?
If he were 180 out, it wouldn't start at all. But if he had his wires mixed up, the back firing would happen. Just double check your work, and then if it's still there, back it off.
FSB warrior
actually he might be 180 out, normally when you backfire... you dont get it running either.
thanks for the input...I double checked all the above. Dist is in correct and wired correctly. I backed the idle and timing down a little. Readjusted the jets on the carb by turning all the way in and out 3/4 of a turn on each. Hasn't backfired yet. It wasn't a constant backfiring only occasional.
ohh and I'm at Ft. Knox.
Cool! I'm glad everything worked out for ya. Do you know of any good trails near you?
