I decided to replace my cap and rotor today because coolant had sprayed all over the old distributor, and I had no idea how old they were anyway.
I *tried* to do the smart guy thing of moving one plug wire at a time over to the new distributor cap, but there just wasn't enough slack in the wires to do so.
I'm sure you see where this is going.
I pulled the rest of the wires off, put on the new cap, and put the new wires on. The Bronco proceeded to run crappy. Horrible vibration that shook the whole truck.
I first tried the standard firing order, 1-5-4-2-6-3-7-8, as below.
1 8
5 7
4 3
2 6
When that didn't work, I remembered the guy I bought my motor from telling me it was an HO... which I didn't believe. But, I tried the HO order anyway:
1-3-7-2-6-5-4-8
1 8
3 4
7 5
2 6
That didn't work, either. The truck ran even worse.
As it turned out, the parts store gave me the wrong rotor, so all I replaced was the distributor cap. I'm assuming it's on correctly, with 1 at the back, as diagrammed.
Could it be a bad plug wire, or what? The plug wires are in pretty bad shape. (UPS is bringing me Ford 9MM's.) The only other thing I did was use some throttle-body spray to clean out the throttle body.
1 8
5 7
4 3
2 6
1-3-7-2-6-5-4-8
1 8
3 4
7 5
2 6
