1 - 19 of 19 Posts
Okay, tell me what you think of these pics... There will be more to come sometime.
The 10th draining of my radaitor in two days, and this is what is still coming out:
My old skid plate:
and, My Tailgate:
Coming soon: "What I found when I took off the rotors"
College User
Nice tag, you put a radiator flush into it, or just filling with water and emptying it. That shows it was not taken care of and checked on a regular basis. Hopefully the rotors will look better for ya.
But what does mine say?
That's just plain nasty, but I'm sure we've all been there one time or another. This bronco had huge rocks of carbon under the valve covers when I bought it and did the rebuild. Yieeecck! Keep the pics comin. We could make a thread on neglect or bad maintenance.
:stupid
Just add one of these to your heater hose and attach a garden hose to it, and run it until it's clear.
Then just add about a gallon of antifreeze (assuming a stock radiator) and top it off with more water.
That'll get ya pretty close to a 50-50 mixture.
-Paul
Screw the Jeep Thing
Ya tire or a new radiator or if your in a place that will let you. Stick a hose down it and see if it gets clean.. Thats what the guys at the quick lube here do..
Thats an interesting pic. by the way..
Time for a new skid plate too. Tail gate doesn't look to bad.
...About flushing the radiator...
I've got to do a flush here in the next few weeks, but I've been holding off becuase I didn't know how to dispose of the old coolant - my stuff is ethelyne glycol - can I just flush this out to the storm sewer?
Ryan
no, you can't pour it into the storm drain. What i've done with mine is, collect it into a designated bucket, then funneled it into old gallon milk jugs. I've called around, asking each shop if I can drop off my old coolant. Around here, the steel scrap yard can take it, as can several mechanic shops - You might also call your local dump station, and ask if they can take the old coolant
College User
All car dealerships with service centers have a coolant tank, if you stop by and ask to leave yours they should not have a problem.
Discussion Starter · #17 ·
Tunedup said:
Looks like someone over did the block seal on it. I would be careful about flushing it to much or you might unplug the leak that stuff is blocking.
Would it still be coming out looking like block seal after the 10th flush? I drain it, run water through the radaitor until it comes out clear at the bottom, plug the bottom, fill it up, run for 15/20 mins, and when I flush, it comes out brown again. I think I'll get myself one of those garden hose adapter things.
Thanks guys.
G
Nasty lookin rust water.
Here is a tip,
Dont put tap water in your truck. Flush it with the hose but dont fill it and cap it off with tap water. Use distilled water. You wont have a buildup of rusty mineral deposits.
1 - 19 of 19 Posts
