So I topped off my radiator on Saturday, and I rushed and forgot to put the radiator cap back on. Long story short, I started overheating last night because water was coming out, I threw a gallon in it, drove to 7-11 and the only coolant they had was the green stuff. It said it was for ford 2000 and earlier, and I had previously put Peak Yellow, safe to mix with any color. Anyways, it took another gallon of that and then it was full. I drove home. When I woke up this morning there was a big puddle under the car. I looked at it after work and the pump is leaking from between the pump and the pump plate. The weep hole was dry. It is a pretty steady leak, probably a drop a second. So I have a few questions here. One, would the green coolant cause the gasket to leak? Two, if I take the pump off and find out it is the gasket, should I just replace the gasket? Three, should I just replace the pump?
How about getting this pump, instead of the regular pump?
http://www.oreillyauto.com/site/c/d...=Search_01398_1106064_3069&pt=01398&ppt=C0331
So thanks for the help.
