Hey, my passenger front wheel drives on a lean, so ive jacked her up & yep!!! there is play from top to bottom, not side to side. can i simply go to ford get a ball joint & undo that humungus nut & split pin & it will fall out, or do you need special tools... i do have a ball joint seperator, is this where you would use it.. does the disk brake have to come off, or the brake line at least??
:shocked
:shocked
[/Remember in order to get that bolt really tight--------STRIP IT...., THEN BACK IT OFF 2 TURNS.... I]
